No backward move but only forward with serious slip
als804
66
kimcheon, ROK
Hell i feel like my transmission th400 in M1009 is burnt. It looks normal but malfunctions. Fluid level is normal and shift linkage is normal . After i did very hard mudding with m1009 i noticed sth is wrong.
The problem is move forward only with very serious slipping. Actually almost no move. If i put in reverse, it goes forward only with serious slipping. I feel like i can’t shift it but linkage looks normal and move.
At P R N D 2 1, it barely move forward only
any idea?
cwc
156
Sweeden, KY
Going forward in reverse after "very hard mudding" could be that the forward clutch plates welded together as a result of extreme heat from slipping.
Sent from my motorola one 5G UW ace using Tapatalk
WWRD99
1,922
York Pa
Going forward in reverse after "very hard mudding" could that the forward clutch plates welded together as a result of extreme heat from slipping.
Probably binding the gears in the sun with the band too.
