Recommended tire pressure
Enforced_Leo44
Parma, Italy
Tried do to a bit of research but didn't really find a "complete" answer
I just got my hands on some 24 non-paired bolt rims, with a set of Goodyear MT on their way, and I was wondering what the ideal tire pressure would be once I go on about installing them on my M998
Keep in mind that I'll mainly go on hard roads, by "mainly" I mean 99,9% of the time, and that 0,1% will be the lightest of offroad
The only thing that I know for sure is that Max PSI is 50
Any advice and clarification would be greatly appreciated!
  • Like
Reactions: OBX
Coug
4,713
Olympia/WA
How much does your truck weigh?
My truck is about 7500 lbs and I run around 30psi on BFG Baja Load Range D
You might be better at 20 or 25psi depending on what your truck weighs.
Here is a method for figuring out what works best for you
Enforced_Leo44
Parma, Italy
Curb weight should be 5200lbs and Gross weight 7700lbs if I'm not wrong, it's a standard M998A0 with soft top and soft doors
Enforced_Leo44
Parma, Italy
Just keep in mind these wheels are tires are designed to have runflats installed which keep the bead on. If you go without runflats and have low tire pressure you could lose a bead.
This is another thing that I was wondering about, excluding the possibility of a air leak, I should be fine running those at a high enough pressure without runflats or beadlock inserts, right?
MarkM
1,144
2,093
WOBURN. MA.
I went a little higher with my 24 bolt MTRs as it helped smooth out the vibrations of the tires. Made it ride a little stiffer but this truck will never be looked upon as comfy anyway. I had a tiny leak in one of my tires and found it would go down to less than 10psi before you notice the tire is low. I ended up getting those little tire monitors that go on the tire valve. When at greater psi than rated it will stay in the green and go to red when below the set pressure. Great little gadget.
Mark
williamh
696
SanDiego Ca.
Mark
If your gonna do show n tell you should include a link 😉
I’m having a little trouble finding them for some reason.
