Replacing fuel filter
Enforced_Leo44
Parma, Italy
I'm soon gonna replace the fuel filter in my M998, and I noticed that inside the filter itself, there's also a little white plastic cylinder with a fine net all round, which I suppose is the separator
Do I necessarily need to replace it with a new part as well or can I just take it just and give it a clean?
(I'm gonna attach an image to make sure we are on the same path, the part in the red circle is the one I'm referring to)
FlameRed
642
Florida
When I did this I bought a kit that had everything. Not sure it is worth doing piecemeal. Just google: HUMVEE FUEL WATER SEPARATOR FILTER M998 4330-01-189-0889 And Main Fuel filter A910162 come with the orings usually.
At the time I bought this last year, there was no HUMVEE tax on this particial part kit where normally a $20 is $200 with only $50 shipping added for good measure.
T9000
370
California
I would check that you get the Kydon manufactured fuel filters (it should have their CAGE code on the box, ideally from the known vendors that sell mainly OEM parts, even AMG sells it), as there are so many others selling Chinese fakes as OEM.
TNDRIVER
569
Cleveland,TN
If the truck is "new to you" I would replace it initially then wash it out, not "brush" it out as long as it looks ok or for a couple more changes, Its the water seperator. Fuel will pass thru and the water should accumulate in the bottom of the filter. Drain it regularly into a clear container , let it settle and eyeball the bottom for water. If you are new to diesels a fuel treatment can be added if you have regular water in the fuel. It kills bacteria that grows in the fuel tank. And anti gel for the cold weather "if" it gets cold in Parma Italy. My two cents.
