5TID's M923A2 ROPS build thread
5TID
278
53
Boise, ID
After driving it a bit with the exhaust wrap, I swear my EGT's (which are probably due to lower intake temps) are cooler with the same driving. So I doubled down a bit and we'll see what they do now.
DeMilitarized
1,096
Gainesville, GA
View attachment 899244View attachment 899245
also check your restriction gauge. If it maxes out I believe a m915 air filter innner and outer will fit with modification to the filter housing and flow more than enough for the little 8.3. I have a m915 and tried the filter and it is the same diameter as stock but longer so removing the baffling at the end of the filter housing should make it fit.
5TID
278
53
Boise, ID
Had fun at the parade this weekend, there were over 100 entries and I was first in line (after the VFW and main parade sponsor of course, both of which are always first).
