littlesfmtv
- 119
- 33
- Memphis Tennessee
I just recently picked this up for an RV conversion. Lots of plans, lots of challenges. My intent is to extend the box front and rear, which I may regret immensely once I am through planning this thing out. Engine has less than 1k hours, no abuse codes, no fault codes, and the valves were all within spec on adjustments. Mechanically, the truck is in pretty good shape. It was stored in the desert at some point, as the metal condition is generally very good, but some of the rubber and soft bits are obviously a bit dehydrated. The box is not in as good of shape as initially hoped, and someone in its life definitely did not read the TM about making sure the tracks were clear before closing. It operates fine now, but the floor is now fixed in place as opposed to folding. I see this as a benefit, but I am 6' and the head clearance on the pull-outs is now ~ a 1/2" to the top of my head. When extended, clearance is fine. The box is also not watertight, as the door seals are all pretty hard and the sealant on the structural roof joint has some light seeps as the sealant has hardened and come off in places. Good news is there is no delamination, and the box is built ridiculously stout. The truck also came with a massive 3 phase extension cord and reel that I have no use for. If interested just message me. The box is 9k pounds empty.....
