- 1,686
- 4,550
- Portland, OR
Does your voltage regulator have LED's?
no. its a 200amp dual volt unit off a HummerDoes your voltage regulator have LED's?
Have picked up several 12/24 bussman convertors when saw them on sale for inevitable issue to arise like this. one to just balance batteries and other incase this alt goes out.Sounds about right. If its a Neihoff you can get the troubleshooting guide from their military section. It should have a procedure for determining wether it is an alternator chassis or regulator fault.
Depending on how available the humvee alts are,this sounds like a great time to swap to a straight 24v alt and a 24-12 converter...
the docs for this altSounds about right. If its a Neihoff you can get the troubleshooting guide from their military section. It should have a procedure for determining wether it is an alternator chassis or regulator fault.
how much of 28v output though is indirectly lost though when you send some juice away thru a converter to create some 12-14v out of the 24-28v bank (with LMTV in mind). Alternator still has to produce enough power to full fill all needs. Such as the dual volt 200amp is think you guessed at max times it was about 140amp used for 24v side and 60amp for 12v side?? (may be remembering numbers wrong.)@24, You don't really need a very high output alt. 100A @ 28V is 2.8KW of power. A 100A alt would easily feed the OEM 240AH 4 battery bank In standard lead-acid. In fact it would just barely be past full load(108A) to feed that same bank if they were AGMs. A 125-150A alt would be great…
Where they went wrong was trying to pull 12 out of the middle of 24 and using that dam dual volt alt. Because the alt output is limited by amps thru the windings, pulling 12 out of the middle of the 24 limits the overall alt output by ~1/3(~1900W), and doesn’t leave enough of either to feed the monster bank Properly.
if they would have just used a straight 100A@24v alt and a converter/equalizer, and perhaps a solar float charger, these trucks would have been fine electrically until AGMs came along, then a 150A would have kept up their good reputation
a 50 or 75A alt would feed a pair of group 31s which is what should be in there anyway…
Yea I think you are remembering the numbers wrong. I think those are what that alt was capable of, 140A@24 and 60A@12. You don’t need a lot to make 12v from,24. The lighting load on a lmtv is 26A(33 on a 1079). thats only 13A@24v plus a little for converter efficiency. With standard lead acids a 240AH bank wants 60, so a lot left over. That 200A humvee alt should have been what the LMTV was delivered with initially, but you can do the same thing with a 100A single volt as it is way more efficient to not pull half of your alt amp capacity out of your alt at 12v, and instead convert your 12 from 24 at a 2x rate…60A for the batteries worst case, 40 left over to run the truck and make 12v, so not ever over 100% load@100A.how much of 28v output though is indirectly lost though when you send some juice away thru a converter to create some 12-14v out of the 24-28v bank (with LMTV in mind). Alternator still has to produce enough power to full fill all needs. Such as the dual volt 200amp is think you guessed at max times it was about 140amp used for 24v side and 60amp for 12v side?? (may be remembering numbers wrong.)
They may not be capable of remote conttol, depends on the alt. Got a model number?Possible solution fell in my lap. little more than wanted to spend but solves couple problems. Two Balamar 24v 140amp alternators with regulators. Price was so good got second one as spare. Pull outs from a military boat apparently. Already have some Bussman converter/balancers I can use to pull 12v out.
After pulling plug hit me that "maybe" could use George Leonard's new dual alt. bracket he made and is selling. Might give me option to maybe put both under the hood. second one dedicated to house batteries. Eliminates need for isolation switch. Gives me ability to shut down alt. charge to house batteries (switch off power to the excite wire? Will that work?) If that would work this would put house batt charging it into solar charge only. (Wiith alt. always excited..... alt otput to house would over power solar output to house thus solar controllers would stop outputting power "according to solar guru's".)
With dual alt. set up.. and depower trigger wire that I hope does like I think it would...... then I could de-power the Excite wire with dash switch.... alt would go off... reduce drag on engine and let solar keep charge up. From then forward; to compensate for any draws on the house bank while driving only solar wold charge. This is an advantage in my case. Have a device to be powered off house batts that while driving I want to run on solar only. Been struggling with how to make that happen yet have Alt. too. An alt. dedicated to house batts solves this if the Exicte wire depower idea works. Wan to run an HHO production system that came off a European diesel bus of solar only. HHO offer's no value beyond engine cleaning if alternator is what is providing the electricity. So shutting down house bank alt. charging thusly putting it in solar charge mode.. fits this plan great. Battery isolators wont do that. Dc to Dc would I think but they are really limited in amp output compared to an alternator. Old school solenoid could but its hard on components and can create charge reduction and parasite drains too.
Balmar 94-140-24-IG w/external regulator MC 624.. likely not the newer version that has lithium charge parameter choice built in.They may not be capable of remote conttol, depends on the alt. Got a model number?
Service/Start. so the 140 wont back down when it senses what ever is there is full? was going to go to just two 12v agm. I have a small 100amp 24v.... but was hoping to put that on my APUthat reg has an ign input so can be easily remote controlled
How big is your service battery?
ok Lithium changes the game for house charging. Must have a dc-dc charge controller, and you can tailor that to whatever excess your alternator will support. You could have 2000AH back there, but the alt is only ever going to see that the charge controller draws…
by your description of how alt. regulator....... regulates... Too large an alt. for amount of batts is not really an issue in that no potential damage is happening anywhere. It is a waste. YES, . but won't slowly or quickly brick anything alt. or battery related....... where opposite as you describe above does brick things. Do I read that correct?,,,,
thats the problem with too large a battery/too small an alt, it will take all the alt can produce and more. Thats the problem with LI and an alt, their internal resistance is so low, it is like trying to power a short if y0u connect an alt directly to them. ....
