kungflu72
Well I have been having some issues with my 1123 power steering system the last few months. It is an 03 with the remote reservoir, and mile marker hydraulic winch. It has always had the normal power steering low whine. No big deal, its a HMMWV. It began whining more, and I noticed the fluid had a pink tint to it. Swapped out fluid and filter. Same thing almost immediately. So I decided to swap out the PS pump. Put in fresh fluid, bled as per the TM. No joy!
So now I started leaning to a suction side leak letting air into the system. I cannot see air bubbles in the remote reservoir, like when bleeding. But this is still my diagnosis. I am thinking enough entrained air to turn it pink. Anyhow, I swapped out all the low pressure hoses, fresh fluid (again) Bled as per TM (again). Immediately the same condition. The longer it runs and gets up to temp, the worse it gets.
My next move was to remove and bypass the PS cooler. Same result as before. I have searched many of the threads on here relating to PS trouble on the HMMWV, and couldn't really find exact symptom diagnosis. I know there is enough knowledgable guys on here to point me in the right direction. But here is what I am thinking:
- Remove every high pressure hose and inspect/swap out O-rings
- Buy a PS analyzer from Midwest Military
- Troubleshoot with analyzer as per TM-Hopefully will reveal if there is an issue with steering gear or hydroboost
- Last ditch effort will be just swap out hydroboost, then steering gear.
