Swap old gasser motor for a Chevy LS 6.0L Vortec?
HDN
4,765
Finger Lakes Region, NY
I've pondered this ever since I looked at an old tractor wrecker with a bad Continental motor - has anyone done an LS swap with a 5-ton gasser? I think the Chevy 6.0L Vortec has the same or better horsepower and torque than the old Continental motors. I'd consider trying this if I found a sweet deal on a dead gasser 5-ton...
19,166
I have never swapped out the old REO 330 (Golden Comet) with the LS, but we swapped about 50 of them with in-line 300 Ford Industrial Six's in a place I worked many years ago.
chucky
18,748
TN .
The 6.0 are out there but everybody is using them in everything around here from jeeps to whatever and you could probly start watching the auto scrapyards and buy a whole total cheaper than a pulled 6.0 and you would have all the other stuff that u need to run the vortec then sale the vehicle back for scrap price and come out to the good !
porkysplace
1,486
mid- michigan
Not sure about the LS motors but weren't they made for pickups ?
I know back when I joined SS there was a member from Indiana who put a Ford 429 in a deuce ,but unsure if it was a 429 car motor or truck motor .
They shared a lot of parts but the truck motors ( f600 ect) had heavier blocks . Ford did the same with FE and FT motors ( 360,361/390,391).
For a parade truck it will probably be ,to use it as a 5 ton was designed for it may have a shorter life .
HDN
4,765
Have you ever been over to Langtry Tx ?
What happens there?
They're used in the GM pick-ups and full-size vans.
Here's a comparison between the L96 Vortec 6.0L (for greater than 10000 lb GVWR trucks, or is it GCWR?) and the Continental R6602 (From TM9-2320-211-20):
Attribute
GM L96 Vortec 6.0L Small Block V8
GM L18 Vortec 8.1 Big Block V8
Continental R6602 Inline-6
Horsepower​
322 @ 4400 RPM​
320 @ 4200 RPM​
224 @ 2800 RPM​
Compression Ratio​
9.7:1​
9.1:1​
6.4:1​
Torque (lb-ft)​
380 @ 4200 RPM​
440 @ 3200 RPM​
425 @ 2000 RPM​
Governed or Max Speed (RPM)​
6000​
5000​
2800 with no load​
(Added the 8.1L Vortec motor as mentioned by @Jbulach )
It turns out that I mis-remembered the torque of the LS motor being equal or better than the old Continental, about 11% less torque. However, the LS motor develops about 44% more horsepower. Is it worth the trade-off? I'm thinking not.
Also, something would have to be done about the gearing on the truck to accommodate the LS motor's higher RPMs needed for doing anything. At least the motor won't be red-lining to get the spec, but it will be spinning a lot faster than the Continental. I'd like to think that modern motor technology can withstand such high RPMs continuously compared to the older motors, but I only know enough about motor design to cause trouble :p
87cr250r
1,904
Rodeo, Ca
Torque at the crankshaft is unimportant, it's horsepower to the wheels that matters. If you change the gearing to work with the 6.0 it will outperform the 6602. Of you change the gearing to work with the 6.0 it will likely not work with your budget.
HDN
4,765
I was thinking about a 2:1 reduction gearbox between the Vortec and the original 5-ton transmission. We'd be seeing up to 760 lb-ft at the gearbox output.
  • Does a reduction gearbox like that exist, or would that be a custom component?
  • Would that much torque break anything on the driveline?
If your going through the trouble, might as well find an 8.1
Thanks for mentioning that motor! I added it to the chart for comparison. I briefly considered re-motoring my Savana 3500 with the 8.1L but that's a thirsty motor for someone who doesn't tow much at this time. I think it's a better fit for a 5-ton than the 6.0L, but I'm not sure about its availability. Seems like there are 6.0L motors everywhere!
porkysplace
1,486
mid- michigan
It doesn't matter how much horsepower or torque it has at high rpm , you need a motor with high torque in the low power band .
87cr250r
1,904
Rodeo, Ca
If you put a 2:1 gearbox between the 6.0 engine and transmission you will likely exceed the torque rating of the transmission. 2 x 380ftlb = 760 which is greater than 425 ftlb.
  • Like
Reactions: HDN
HDN
4,765
That's super-important - thanks for mentioning that :) I really didn't know what the stock transmission was rated for.
gringeltaube
Staff Member
2,275
Montevideo/Uruguay
williamh
583
SanDiego Ca.
The only experience That I had with any sort of a V-8 replacing a straight 6 was after the V-8 had failed ( still ran but the thrust bearing was wasted ) it was in a M-211 GMC and the 302 6 was replaced with a 455 V8 It don’t have any of the low end tork the straight 6 had ( I had an M-135 at the same time ) , it wouldn’t go any faster since the gear ratio didn’t change. Those heavy ass trucks take a lot of low end tork to get them moving , going down the fwy at speed might be ok but when it comes to low end tork. The straight 6 can’t be beat. IMHO
RenegadeActual
13
Az
Don't think a chevy v8 will be as robust as any diesel engine, it may move the truck but for how long?
