WV New Guy
- 1
- 18
- Berkeley Springs WV
Im at work i want to say 1/2 inch mine we just hose clamps on the cooler.
Yes.Question, Is the power steering pump on the M915 the same as the M920? The 915 is a 1984 and the 920 is a 1980, Thanks
Thanks for the information. Would you have a part # for the eaton?Yes.
There is also a civilian eaton style with a remote reservoir like used on civilian trucks and the 915a4s
Freightliner TRW 14-12528-000Thanks for the information. Would you have a part # for the eaton?
O right., thank you very much. Been watching your 920 build and have found a lot of good ideals for my truck. Thanks againFreightliner TRW 14-12528-000
NsN
2530015248163
No problemO right., thank you very much. Been watching your 920 build and have found a lot of good ideals for my truck. Thanks again
Baskin truck parts in Covington TN has a blown big cam 3 with everything on it you would need. It has the remote reservoir pump on it. They want 1k for the whole engine and it has alot of accessories on it but it is an air cooled motor at this point. I'll see if I can grab it next week.O right., thank you very much. Been watching your 920 build and have found a lot of good ideals for my truck. Thanks again
Will the original coupling shaft work with the new eaton pump? I'm assuming it will work , but I figured you would know for sure? Thanks
Just checking to see if you were still on schedule to pick up the motor this week. ThanksBaskin truck parts in Covington TN has a blown big cam 3 with everything on it you would need. It has the remote reservoir pump on it. They want 1k for the whole engine and it has alot of accessories on it but it is an air cooled motor at this point. I'll see if I can grab it next week.
