theairguy
- 10
- 3
- Gentry Arkansas
So I have a 6.5 with the 400 amp generator. Had the Hmmwv for a few months. So for the last several months when you start the machine the battery gauge goes up to the green area with a little white line in a few seconds. So one day I started it and it took quite a while to come up like 20 seconds instead of 2 seconds. This is the common thing now, I start it and wait till the gauge reads in the Green. So the other day when starting it never came up to the green just stayed in the yellow. When this happens if you try to turn on the fans for the A/c they don't come on. So I shut it off started again and it came up to the green. Seem like it is slowly taking longer and longer to get to the green. So today went to start it, wouldn't come out of the yellow, fans would not come on. If I throttled it up it would go to the green but fans still not working and would drop right back to the yellow.. So I shut it off and got a meter out to do some checking. I started it back up and working good again, fans and all. So new batteries, new belt and tensioner. no obvious problems. It may or may not do it again when I am home or have a meter handy.. Is this as simple as the regulator going out?
