I purchased a MEP-802a the other month, then went away:
www.govplanet.com
I am back and spent the last couple of weekends working on and off, on the new MEP-802a.
I had purchased it hoping to move the stator from this to my failed mep-802a.
I took most of the tin off of the two generators to find the my 3 jaw pullers were too small to pull the stator end off the bearing.
From that point, I decided to see about getting the new one running as it might be nice to end up with a backup.
In the process, I found all of the pressurized fuel lines had dry-rotted. I replaced all of the pressurized lines and one of the tees as I only had one new one on hand.
The inside wasn't in great shape as it was converted with diesel and a few mouse nests. I couldn't find any chewed wires. It looks like they attempt to put leaves etc into the alternator.
I pressure-washed the non-electrical parts and vacuumed out the unit a few times, it’s much better now.
I moved the batteries from the old to the new.
I filled the radiator with water for now.
I drained ~2.5qts of oil as the oil looked brand new but was to the top of the filler.
I moved the missing relays over from the old to the new one and was able to start it.
I ended up moving the control cube from my old one to the new one as the new one was missing the alternator fuse, two wire start ( https://www.steelsoldiers.com/threa...ote-start-parameter-monitoring-system.190193/ ) and the fuse upgrade.
The battery still won't charge. I expect that the alternator is dead. Do I need a working alternator, or is having a 24x7 battery charger good enough?
https://www.amazon.com/gp/product/B08G3STB1N
The other issue I need to address is the cooling system, as the radiator overflow nipple was missing, and they did some creative work with the overflow/drain lines.
![IMG_1760.jpg IMG_1760.jpg](https://www.steelsoldiers.com/data/attachments/657/657387-e7185f12249989e2809706eeb60da13f.jpg)
I am going to see if a radiator repair shop exists within a couple of hours, as I would like it to be able to pull back in from the overflow bottle.
Has anybody had luck repairing the overflow nipple?
I ran the generator for an hour or so; at first, it was dark smoke. I ran it at ~4779va (90amps at 53.1 volts) into my batteries with the charger:
signaturesolar.com
and the smoke was mostly cleaned up.
What the batteries didn’t want was pushed back to the grid, banked to use this winter.
![IMG_1762-2.PNG IMG_1762-2.PNG](https://www.steelsoldiers.com/data/attachments/657/657390-c6200a94b54da9b0aef176e3caddd65e.jpg)
I still don't know if the 2nd fuel pump is working. I think the 2wire controller will kick it on when the tank is 50% and then fill it up to 75% (extra fail-safe to prevent the tank from overfilling and dumping diesel on the ground).
In any case, I am thrilled to have something better than my EU2000i up and running.
I need to figure out what I am doing with the old one. Do I make it a runner or move the alternator and radiator over, box up the parts I might need, and put them in the basement?
![www.govplanet.com](https://cdn.ironpla.net/i/13392/416/ec481113-704f-44d9-9e23-0701b690658f-full.jpg)
2003 Libby MEP-802A 5kW Generator Set
5 kVA, 5 kW, 120/208 Volts 3 Phase, 5 kVA, 5 kW, 120/240 Volts Single Phase, 120V Receptacles, Fuel Tank
![signaturesolar.com](https://cdn11.bigcommerce.com/s-bi8c0htqsn/products/2604/images/2597/158847d1-0a48-477c-8ec1-1d048007ee1f__99548.1695049455.386.513.jpg?c=1)
EG4 Chargeverter | 48v 100A Battery Charger | 5120W Output | 240/120V Input
Signature Solar provides solar panels, off-grid solar systems, grid-tie, and hybrid systems. Quality solar inverters, bifacial solar panels, complete solar kits, solar batteries. Featuring brands such as EG4 Electronics with their solar battery, LifePower4 and EG4 LLifePower4 and EG4 LL
![signaturesolar.com](https://cdn11.bigcommerce.com/s-bi8c0htqsn/product_images/signaturesolar-solar-reg.png?t=1673984423)
