Rattle on steady state driving
aw113sgte
1,423
La Crosse, WI
New to the FMTV, never driven one before so I don't have a good baseline. Truck is 2007 A1R m1096 with 1800 miles. When on the highway when maintaining 50-55 I have what sounds like gear lash noise. Goes away completely on accel/decel. Do these trucks tend to make some noise from the hub gears? I haven't checked the shims yet. The axles and ujoints all feel tight with the "wiggle" test.
Wingnut13
565
Strafford, NH
I seem to have the same issue. 2013 M1078A1 with 14k miles. I can make it happen at 40-50mph if you manage the throttle to lightly load the driveline. My front driveshaft was out of phase when I got the truck. But after that everything feels tight.
chucky
19,305
TN .
I bet its those kids on the roof when you get up to highway speed ! They always get quite when you accelerate ! Good looking truck the party now beguines !!
Ronmar
8,374
Port angeles wa
I would also expect more noise out of them if they were not properly filled with lube, or the end thrust bearing and washer stack has developed issues. Where did you get the truck from? These things went to excess for a reason, and if it has not been gone thru by someone willing to dot the Is and cross the Ts…
something like a magnetic mount microphone or a go-pro with audio might aid you in localizing noises…
aw113sgte
1,423
La Crosse, WI
Was from MWME, unsure if hubs were checked. Going over the truck some things are checked, other things a bit lacking in maintenance.
GeneralDisorder
6,205
Portland, OR
Typical. Trust nothing. Perform a full hub service including CTIS seals, repack bearings, etc. Lots of unhappy purchases from those jokers - overpriced and overrated in the opinion of many. Better off just getting an auction truck or a private party sale and doing it all yourself so you know what your driving.
What's the DOT date on the tires? Anything over 7 years is garbage so subtract however old they are from 7 and that's how long before you need to do the tire dance - so much fun on a 6x6.
Besides the obvious and the trust nothing sentiment - you will want/need to know how all this stuff works anyway so best dive in and see how it's put together.
coachgeo
3,550
North of Cincy OH
look close at your MTV truck. Note that portion of the transmission sites above the upper chassis rail. To clear the transmission you will need either a third chassis rail.... or put a dog house in you box to hump over it; if the floor plan allows for it.
aw113sgte
1,423
La Crosse, WI
Yep, got that all measured out. I may get a laser scanner and do the whole truck so I can have accurate dimensions for the CAD work. Plan on fully designing it on the computer as that's what I do for my work.
If I do that, I'll make sure to make the files available.
Ronmar
8,374
Port angeles wa
Scanning would be cool. It took a lot of time to get dimensions to get the cab and chassis into autocad. I usually get pretty good the 2nd or 3rd time I build something, so I try and get those first couple of builds out of the way in CAD:)
Lostchain
591
Portland, OR
Sounds exactly like what my truck did. Pretty sure that is the completely normal sound of the gear reduction hubs. Mine did it more or less any time I was holding a set speed above 40, but adding/removing throttle quieted it up. Gear lash was exactly how I thought of it. I rode in another LMTV that did it and also have seen YouTube videos where I can hear it. My hubs had a recent service date and were flawless inside when I changed over to the ECO Hubs. The sound is completely gone now so it was 100% the reduction making the noise.
ckouba
2,018
Oregon
Exactly my experience as well. I was worried I had a diff that needed to be shimmed or something along those lines. It was all in the bevel geared hubs.
