M1078A1 not charging in neutral! FIXED!
TomTime
1,672
MD.
Is this what your looking for???
If not let me know what you need, I'll try and get it from my photographs list of my A1. I have hundreds of pictures of my truck and it's systems I took when I got it home, just in case I needed to look at something without having to go out to the truck everytime.
Tom.
EDIT: I added the two photographs of the PDP, top and bottom from 2002 A1.
20,579
would it be correct to say that is early A1
and below is later A1 as in the A1r).
PS- someone grab and copy these pics to here..... this ad's images will go bye bye soon. Not in position to grab images right now or I would
Images are here now for the A1 truck Dash Components
s-l1600 001.jpgs-l1600 002.jpgs-l1600 003.jpgs-l1600 004.jpgs-l1600 005.jpgs-l1600 006.jpg
Ronmar
8,103
Port angeles wa
I would call the pics with the 4 individual power dist modules/PDMs an A1R…
The A1 panel was a green circuit board with soldered on components and sockets, like in these pics. For the R it appears that they replaced the circuit board with the 4 PDMs and kept the ign relays K1 and K2 on the underside of the same type mounting subframe…
Third From Texas
6,653
Corpus Christi Texas
He has a 2005 so...could be either way ?
BAE had a big roulette wheel and a headless chicken when it came to putting together their early trucks.
"We're out of 3126s? Break out the C7s (but keep using the old rear ends until they are gone). Here, put this grill on that one"
Ronmar
8,103
Port angeles wa
I think S&S did the same thing With the A0. I call them A0.5’s… A1 panel with no LBCD or battery disconnect box…
