- 2,091
- 3,415
- Pepperell, Massachusetts
I found a manual about the gen head at: Gen Head Manual
It talks about using a 12 volt battery with a 30 ohm current limiting resistor to apparently flash the gen head.
See PDF page 52
You may want to test the rotating diodes in the gen head. If they are toast the rotor won't generate any magnetism even though you are applying power to the static exciter.
See PDF page 52
