- 7,556
- 10,599
- Papalote, TX
How many ohms does the speed sensor test to (disconnected)?"Engine RPM" voltage test on the J1 spec is 0.3 V idle, 349A. I got 0.003 V. Actual RPM (the mechanical turning) is fine. 800 idle. It appears even if I manage to get the bolts off there isn't enough room to pull the sensor back to remove, see picture.
are you using AC or DC scales, you do not have a code 71 so I am curious why you are looking at it.
