Doug D.
- 27
- 18
- Winterville Ga
where is a easy place to get a switched wire source in the dash or behind the instrument panel. Just going to power some interior LED lights.
Just looking for a switched wire in the dash---just to be simple.Not to hijack your thread, but this may be of interest to you for interior lights: How To: Interior "Dome" lights - without door switches
To answer your question, I ran wire(s) direct to the 12V post and 24V terminal posts of the battery - fused of course, for power source. And I got ignition signals off the switch behind the dash.
yea i am good with 24 volt as the lights i have are 24 volt. Just need to know what wire i can connect to behind dash that is switched.I ran into a power drain of my batts running it to the 12v batt post (leds) so asked an auto electrician. He said run these to the 14v post on the top of the alternator and establish a fuse panel from there. Havent tried it yet but Im going to.
Sent from my SM-A716V using Tapatalk
Use one of the dash lights to trigger a relay. This way the light can only be turned on when the dash lights are on, preventing you from killing your battery.Just looking for a switched wire in the dash---just to be simple.
