Bogie maintenance
aw113sgte
1,408
La Crosse, WI
Can't find anything on here of the TMs about this (only the part breakdown)
Seems to have a fill plug so I'm guessing oil filled till comes out the hole? Any other ideas?
Guyfang
27,141
Burgkunstadt, Germany
Open up TM 9-2320-366-20-1
Scroll down to PDF page #160. That is the LO, Lubrication Order. It tells and shows what and where to lube.
Read/scroll down to PDF page # 161 and you will see, Rear Axle Bogie, Drain and fill. See note #28 and View AG
View AG is on PDF page #162
Note #28 is on PDF page #163
On PDF page # 160 the table will tell you how much lube, and what kind of lube.
B-Dog
293
Denver, CO
I needed to look this up anyway so I thought now would be a good time. I think your page numbers might be off, by about 1000; you meant page 1610, 1624 & 1635.
More maintenance details are in Unit Maint 4; 9-2320-20-4, section 10-5; pdf page 620
Oil type is in appendix D, Section II, item 39, Gear oil 75W; pdf page 1318
Fluid Amount is in appendix H, section H-5, 0.5 qt; pdf page 1378
20,760
AW= Thanks for a new word in my vocabulary(Bogie).
Writer of the TM must of been from the UK.
Here in the Southwest we just call then Axles..lol
I kept looking for the tracked vehicle.
Haven't seen one yet in this thread...
Bogey (Bogie?) wheels are indicated, 3rd up from the bottom left of the picture.
