When your TCM takes a bath...
Milcommoguy
2,386
Rosamond, CA
A little footnote to computer's, microprocessor's, rom's & prom's when handling. Follow proper ESD procedures. Electro Static Discharge. The little static spark one doesn't see or feel and POOF... Time for more parts., now or later when they fail. 🎆 Nice video.
Sparky the electron just Smokey Beared your electronics, CAMO
TOBASH
3,905
Brooklyn, NY
You will see a few of us call that “the little green smoke escaped” or “you let the green smoke out”. We’re describing a blown unit.
Always ground yourself when working on components with delicate electrics. Just tie a stripped wire to a radiator and tie the other end to your wrist.
Mogman
10,402
Papalote, TX
I am pretty sure you are not going to find it for any civilian 6.5L application even the H1, the TCM they used in the HMMWV was for an early 90s GM truck with a 6.2L and a 4L80 transmission.
99% of all the 6.5L used the DS4 IP so those engines had an ECM and a different TCU
TOBASH
3,905
Brooklyn, NY
Mogman
10,402
Papalote, TX
