Wobbling Pulley Stuck
Hummer Guy
822
United States Louisiana
Anyone here has try removing the key before? I've been messing with it for 2 hours and only have moved it up on each side. My next plan is to cut it in half but the weather messed me up
Mogman
10,402
Papalote, TX
I have removed tons of them, I have never had one I could not remove with a chisel or a punch, it is in a half moon hole ether way you move it it will come out.
Hummer Guy
822
I tried that for an like almost 2 hours, it just came up on either side and wouldn't move anymore, I ended up cutting it in half with a dremel and then I was able to beat it out.
Is there any chance I had the pulley on the wrong side which caused it to open up inside? I remember that pulley would back itself out a little when I drive for a few miles, it would basically even itself out with the other pulley's, this caused it to have a little space between the washer and the pulley and the washer will usually vibrate while the engine is running
Mogman
10,402
Papalote, TX
If that was the case then the pulley defiantly was not tightened up enough, it should be TIGHT against the shoulder on the alt side of the shaft, this pic shows the side that should go in against the shoulder.
If it needed to come out to align with the belts you had the wrong pulley on it, this one gives more offset towards the front of the vehicle.
Hummer Guy
822
I have one like this but it was too far out, this was the one I had that was to far out 8-Groove Belt Pulley ; Humvee M1114 ; RCSK18685 RCSK18219 3020014445447 | eBay
Hummer Guy
822
I have a clutch pulley on a broke 200a generator, most likely I will try to get that off. I'm going to let it soak in PB blaster for a few hours and then make an attempt at it, I hope that pulley isn't broke as well. Its crazy that the clutch pulleys cost between 400-600$, I had bought mines for 260 last year and now its over $500 on the same website
Hummer Guy
822
Done that, old clutch pulley came off but left the bearings on, I guess that thing is destroyed
Mogman
10,402
Papalote, TX
I got my new pulley in, a solid one, do you guys use a lock washer for the nut?
I don't but it's just a personal decision, sometimes the washer expands and tries to push out from under the nut, I am still in shock at how good the shaft looks.
How does the pulley fit without the key in it?? any slop?
Mogman
10,402
Papalote, TX
2 months later, same thing happening again, I started to hear the same slop noise and decided to inspect it, pulley is back wobbling. It seems like the clutch pulley is the only safe one to use for long term, I've driven my truck a lot over the pass couple of months
There is no reason that pulley should fail, I have had no issues with mine at all, it ether did not get tightened enough or the shaft was damaged the first time it was put on loose.
Retiredwarhorses
4,557
Brentwood, Calif
No slop at all, it still has a perfect fit on it
what Did you use to secure that pulley? That is nothing I’ve ever seen.
Also….i believe you have the wrong pulley unless you have the entire small pulley conversion kit installed which would have
provided you everything you need, pulley, belt, mounting hardware.
Hummer Guy
822
Its a Plumbing nut, I had miss place my previous nut but I found it last week and was going to change it.
I don't have the small pulley conversion kit but this pulley is the same size as my seized up clutch pulley
Hummer Guy
822
I got the pulley off, the shaft seems to not have any damage, could it be that the 200a generator is just too strong for the solid pulley and put too much stress on it when shutting the truck off over time? The clutch pulley never did this for the 2 years I had it on.
For the nut, the original generator with the truck had come with this strange looking nut in the picture, and the second new generator I had came with a nut that had grooves in it (I lost it)
