DREDnot
- 435
- 63
- Phoenix, AZ
Trying to help a friend get his BAE style A/C to activate the clutch on the compressor. I have an electrical schematic im working with
My friend took it to an A/C shop first. They hooked up their A/C gauges to it and told him the hi and lo pressures were good (without the clutch running) but they didn't know the electrical system to diagnose anything further. So, I'm operating under the assumption that its not a hi or lo freon condition.
So far I've determined that...
There is constant 24v into and out of the two circuit breakers.
The A/C power switch works and turns on/off with the start switch in run.
The front blower works hi and low.
The rear evaporator/Blower assembly does not run but has power at the 720A pin at the cannon plug.
The ground wire to the compressor at 7J has continuity to ground.
There is no power at the compressor at 436 with the engine on or off in run.
There is no power to the high pressure switch 436.
There is 24v at the 445B connector at the right rear condenser assembly
There is continuity to ground at the 7H at the RR condenser.
Before I just jump 24v to the compressor as a fellow owner suggested Im not quite clear in what causes the rear relay to close and start the whole thing running when its operating normally.
My gut says the relay is bad but im not sure of the function of the water valve (on the engine?)
Im also not sure what gooes on inside the rear evaporator unit to send power to the main relay(415) that closes the relay
Or anything else I missed?
