Will a cucv run with missing belts?
Finnegan1008
167
Connecticut
I have whats probably multiple squeaking/noisy accessories on my m1008. It's difficult to pinpoint exactly what is causing the noise.
My questions is can I temporarily remove belts to try to isolate the problem? If my batteries are charged up can I crank the engine? I was planning to do this on a warm engine so no glow plugs needed.
20,741
Perfect! Thanks
Without losing your fingers, if you have a bar of soap you can stop belt squeaks. OR, if you are able to use that same bar of soap and rub the inside of the belts (again - one at the time) rotate the motor a little and rub more soap.
If it is a belt squeak, it will disappear for a while.
Won't last long if it is raining!
