Brake upgrade options
Finnegan1008
167
Connecticut
I think the stock brakes are perfectly adequate, but I have wondered what options are out there if I ever decide to upgrade in the future.
Are there any junkyard bolt on parts that can be used a worth while upgrade?
nyoffroad
740
Rochester NY
depends on what you have, I have disc brakes in the rear and the kit is available or you can fab up your own easy peasy, but that's for full floating rear ends.
87cr250r
2,131
Rodeo, Ca
Convert to DOT 3 or 4 fluid. I haven't done this. I did rebuild my calipers and had a clear waterline on the pistons. Or, remember to turn your calipers upside-down when you flush the fluid.
With that said, I've never heard of any complaints with the brakes on the civy trucks. It's a system built by Bendix and is in many trucks by many manufacturers.
OEM pads aren't available anymore. I've had issues with aftermarket pads spitting shims and squealing a lot. I bought Wagner pads last time as they don't use shims. The front has been good. My rear shoes wore down due to an oil leak. I'll replace them eventually. It cut a step in the drum so I'll have to replace the drums as well.
Barrman
2,181
Giddings, Texas
Hawk brand brake pads on the front make a huge difference.
2000 or newer Chevy truck rear axle with disc rear brakes that have the top had drum parking brakes. Fabrication required.
Ilikemtb999
46
Denver, CO
There’s a company that allows you to put modern 2500 brakes or dodge brakes on a Dana 60. I’ve got the 2500 setup with slip on rotors
Ilikemtb999
46
Denver, CO
Was is a worth while upgrade? Either better stopping or cheaper consumables?
I haven’t driven it with them yet but I had an 07 Sierra with them and they were great. I can’t stand the single piston d60 ones. I also had the calipers already, bought Yukon brand hubs and turned them down on a manual lathe and then the rotors just slip right over.
