Not a bad idea! Can we talk you into taking a pic of the crane setup and the ramps on the truck (to gauge the angle)?I have a 1k crane in rear like lmtv has but also have 12' Heat treated boards with angle iron underneath for the atvs. Steep yes but it works.
Say..what is that box in the back of the truck? LOL. I only jest since I asked already on FB.
Looks like you got the whole ramp thing sorted out. Good luck to you.I'm not opposed to a crane, but a crane is not really a direct substitute for a ramp, or vice-versa... so lets try to keep this about ramps. I'll probably end up with both anyway.
I'm not too concerned about 16-20' ramps. My idea is that they could fold up. So you can either have ~16' ramps that fold into 2x 8' parts that fit under the bed width, or 20'+ ramps that fold into 2x 10'+ lengths that you put up in the bed. Since the ramp angle is steep, you can make the ramps pretty strong by having them be a fairly "deep" structure.
Bump
Anyone got pictures of ramps they built? I'm looking to make a ramp that I can roll a dolly on, I have a winch in the bed so I can even winch the dolly on the ramp as well. At the exact most, I'll have 800-1000Ibs on them. My plan is to go with some treated wooden ramps at 10 feet long.
Wouldn't these be too short for any MV?I would go find the slide out ramp from an old u-haul truck and build it to slide in your frame well the same as the u-haul and notch your bed the same way where you slide the ramp out and lift up to set in the notchesView attachment 909187
Cause i didnt need a ramp ! I needed a staircase a girl could pick up and slide in the frame ! In case i got over served !
Get one long enough !Wouldn't these be too short for any MV?
But wouldn't a ramp be more useful if say, that girl was unconscious?Cause i didnt need a ramp ! I needed a staircase a girl could pick up and slide in the frame ! In case i got i got over served !
No !!!!!!!!! It scratches them all up ! I read somewhere ! Best to get them in the truck before before you administer the love potion #9 ! Dont pick a bigun if you cant pick her up ! Saw it on special victoms unit (tv)But wouldn't a ramp be more useful if say, that girl was unconscious?
Asking for a friend.
;p
I should have been more clear.No !!!!!!!!! It scratches them all up ! I read somewhere ! Best to get them in the truck before before you administer the love potion #9 ! Dont pick a bigun if you cant pick her up ! Saw it on special victoms unit (tv)
