- 5,252
- 3,968
- Charleston, WV
It’s alive!! I ran a new piece of 3/8” line from the inlet on the mechanical pump to a jerry can full of diesel. It only took a few seconds of cranking to get fuel to the filter inlet. Another few seconds got it running out of the filter bleed valve. A little more cranking got it sputtering and then running! Also, as you will see in the video, I have a significant exhaust leak at between the passenger side up-pipe and the turbo. But at least it runs!
youtube.com
Now, I just need to figure out what’s wrong with the pump supply line. I’m thinking it’s the check valve, but we’ll see.
![IMG_3458.jpeg IMG_3458.jpeg](https://www.steelsoldiers.com/data/attachments/664/664268-c893198f79017d3b8ec112a218c3a2fa.jpg)
![youtube.com](https://i.ytimg.com/vi/NC4Z3asiFx8/oar2.jpg?sqp=-oaymwEkCJUDENAFSFqQAgHyq4qpAxMIARUAAAAAJQAAyEI9AICiQ3gB&rs=AOn4CLCN1h50f9cY7-uYauquKDHoMjylbQ)
M1152A1 HMMWV fuel system priming and first cold start
My HMMWV lost prime after the check valve in the supply line cut off the fuel. I ran a rubber line into a jerry can full of diesel and then began priming the...
