hmmwv-newbie
- 34
- 18
- Arkansas
Where can I get some more of the rubber coating they used on all these bolts that are near the battery. I'm paranoid about arcing the battery with the seat cover...
Yep thank you!
No the HMMWV does not have an isolated groundIs the HMMWV not isolated ground? In that case it shouldn't matter if a terminal touches the body.
Unrelated but, are those grounding harnesses I see many people installing truly necessary? I have a Rev truck and I’m wondering if any problem that may have existed has since been fixed at the factoryNo the HMMWV does not have an isolated ground
NoUnrelated but, are those grounding harnesses I see many people installing truly necessary? I have a Rev truck and I’m wondering if any problem that may have existed has since been fixed at the factory
.Unrelated but, are those grounding harnesses I see many people installing truly necessary? I have a Rev truck and I’m wondering if any problem that may have existed has since been fixed at the factory
