![www.greatlakesskipper.com](https://www.greatlakesskipper.com/media/catalog/product/a/4/a49d25b7b6c6ba72b812740ec0472585_1.jpg?optimize=low&bg-color=255,255,255&fit=bounds&height=700&width=700&canvas=700:700)
Kraus & Naimer Boat Rotary Control Generator Switch Terminal USM183 | Blue 10A
Boat part number 1102855 is a new rotary control switch terminal from Kraus & Naimer, part number USM183 .
Master Switch won't engage starter. Just clicks once and nothing happens. If I recycle the switch back and forth it will eventually turn over and start. Saw this switch online and was wondering if I could use it as a replacement.Which switch location are you trying to cross? S1?
Thank you Sir. What is the big auction site?The switch in the first post will NOT replace your S1 Master Start switch.
I assume your S1 switch is a blue plastic one. Failure prone for sure.
Ideally, you'd want to replace it with an Electro Switch 75902LV. They will last a lifetime, but are pricey.
You could replace it with a 88-21160 5930-01-368-5160 for less money but they aren't too reliable.
Both available on the big auction site.
So do I need to take the sBefore you start throwing cash at a new switch, you should not only deoxidize the one you have (my recommendation is
https://www.amazon.com/gp/product/B00006LVEU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1), but also reference the TM.
TM 9-6115-641-24 has a troubleshooting section. You want to view Table 2-6. UNIT TROUBLESHOOTING "1. ENGINE FAILS TO CRANK." and go through the steps. You may find after the switch is cleaned... its not the switch.
TMs are free... if you don't have a copy, you can download them from the TM section here on the site.
So do I need to take the switch apart to clean it?Before you start throwing cash at a new switch, you should not only deoxidize the one you have (my recommendation is
I second this motion...Deoxit is some amazing sauce, I've been pleasantly surprised every time I use it. Reccomend a soak and multi-cycle treatment to the other rotary switches while you're there, it's like WD-40 for switches/contacts!Before you start throwing cash at a new switch, you should not only deoxidize the one you have (my recommendation is
Thanks for all the feedback. The problem turned out to be the oil pressure sensor. I noticed that the oil pressure gauge was reading all over the place so at first I thought I'd change it out . Then after giving it some thought I figured if the gauge was bad it would either be stuck somewhere or not reading at all. SoBefore you start throwing cash at a new switch, you should not only deoxidize the one you have (my recommendation is
