cdub0451
- 21
- 3
- South Alabama
Hi all, I'm fairly new around here. I can't remember when I joined the forum, but have been reading heavily on the LMTV since early '23. I finally pulled the trigger on a Mar/2004 M1078A1 and learned quickly to enjoy chasing all of the gremlins and fixing them as best possible. My current focus is on the battery/alternator/grounding system and have decided to do a Ronmar type setup. I have a Bussman 100A 24-12 Equalizer/Converter on it's way in the mail and converted to a two 24F battery setup. The catalyst for this project is that I'm somewhat confident my Battery Disconnect Relay Switch died and brought down the four 10 YEAR OLD Exide 6TMF batteries. I bought the batteries and hooked them up in a 24v in series config with the 12v tapping off the center jumper.
Turned the disconnect switch and nothing. Flipped the disconnect switch in the cab; nothing. Flipped the ignition switch just to make sure and pressed the start button. Nothing. No lights on dash, no disconnect solenoid sound, nothing. Haven't been able to do anything since it started raining for the first time in a long time. Next steps are to remove the Battery Disconnect Relay Switch, jump from the manual disconnect with some 2/0 to an isolated circuit busbar and terminate the 24/12 vehicle power cables to the appropriate lugs. On to my question.
I am still running the stock alternator but want to know and cannot find info saying definitively if there is a 24v alternator that will bolt directly to the green alternator bracket (is it a J180 Hinged?), or the Cat gold one under the green one (looks kinda like a Pad Mount type to me), if it is an alternator bracket at all? I'm looking for something in the 150-200A range.
Thanks in advance
Christian
Thanks in advance
Christian
