taskunitbruiser
- 51
- 28
- Alabama
After replacing the glow plugs (4 were bad) the engine starts amazingly easy when cold. The "wait" light stays on about 10 seconds when cold, everytime. If the engine is not fully cooled down (say I drove it an hour prior) the wait light stays on about 1/4 of a second (i.e. a quick flash) and the vehicle is quite hard to start.
I show a current draw when this happens and also when I unplug the main temp sensor connection near the TPS. When I did transmission diagnostics, I would always unplug this per the TM, but always wondered why the dash gauge showed it drawing current. Where does current go?
For the warm engine start problem I suspect the temp sensor is faulty and telling the ECM/Smartbox to not activate the glow plugs. I was told this engine may have two temp sensors, one for the dash gauge and one for the ECM/Smartbox/computer. Is this correct? My dash gauge temp sensor seems to function normally. Does anyone know the location of the second one?
Again, only ever have issues when the engine is still a little warm; wait light flashes once and it just sucks starting it. Anyone had this problem?
