Coolant heater addition. 1997 1078
Blairg
105
California
Was wondering if anybody has added one to their truck? Would like to heat water for the camper as well as have the motor in the loop as well. And if you have added a heater where did you tie into the motor cooling loop.
Thanks,
Blair
TechnoWeenie
1,797
Nova Laboratories, WA
While a hydronic heating system sounds great, it adds complexity.
With complexity, comes the increased opportunity for something to go wrong.
Why would you complicate one of the few systems that's REQUIRED for your engine to operate?
You get a coolant leak, and you're dead in the water. Sure, shutoff valves might work, but how long before you realize you've dumped all your coolant on the ground as you're driving down the highway? You got 10 gallons of coolant/distilled water on hand to top it off after you shut off the leaking lines?
Better off with a standalone heater, IMO.
ramdough
1,731
Austin, Texas
Thanks,
Blair
I plan to have a stand alone hydronic heater for the camper and maybe I will add the truck with a heat exchanger so the loops don’t mix. Still on the fence for the engine side.
Blairg
105
California
My current design includes a marine water heater/tank and a diesel heater that will be used for the camper. I wll be able to use both 110v(shore power or inverted) or diesel depending what the siuation is. My thought was to add the ability to plumb into the motor cooling system if needed. I appreciate the addition of a failure point but pre-heaters are pretty common. I think the FMTV's came with a pre-heater in the acrtic packages.
Blair
TechnoWeenie
1,797
Blair
Some would say it's a minor risk.
They're probably not wrong. The odds of something going wrong are slim. The problem is, if they go wrong, can you implement a FER and get on the road?
You're on a forest service road and you get a leak.... how long until you realize you dumped all your coolant? When the overtemp light comes on?
How you gonna get down off the mountain?
Got a way to replace the coolant? I mean, I guess at that point anything liquid will do, but...
I just look at as certain things are mission critical.
Oil.
Fuel.
Coolant.
A truck will run with damn near nothing else working as long as you have those 3 things.
You lose one of those things, and you're dead in the water... So, just me personally, I wouldn't want Murphy to come visit me as I make things more complex.
My mission goals might be different than yours. If it's a grocery getter, stuck on pavement, and never more than 4 miles from a truck stop or Walmart.. then no big deal.
Going off road? Added complexity.
Same inverse reasoning is why I'm gonna have multiple sources of heat AND blankets/cold weather gear... No one has ever complained that their plan B or plan C saved their butt when plan A failed.
Gibberogill
Idaho
I too am in the process of converting an M997A2 ambulance into a camper. I have purchased the Espar D5S diesel hydronic heater and have a similar plan to Blair. I read the comments made to Blair above and would like to address those first.
Added complexity: Yes, this definitely adds complexity to an already complex thermodynamic energy conversion plant (diesel engine). However, I am not creating a life-support piece of equipment. I am creating a hunting camper. I will not be in a primitive third world nation without resources to address unanticipated mechanical issues. I doubt I will face hostile forces intent on my destruction. I want to enjoy my time in nature and retire to a comfortable place at night so I can enjoy more time in nature.
Another way to look at this issue is by identifying the objective of the mission I will undertake. In this case, it is a hunting experience. What equipment do I need to fulfil that mission?? For me I want a warm place to shelter from the elements, a vehicle that will reliably start in very cold weather, and hot water. This diesel hydronic heater fulfills these needs remarkably well. This system will add 5-10 liters of additional coolant, there will be shut off valves to and from the engine if I want to isolate that loop from the camper portion of the loop if a leak were to occur. If anything, this system give me coolant volume redundancy with many additional benefits which further the intended purpose of this vehicle. In addition, I will not have to source and store an additional fuel source like propane.
So . . . given that I am willing to deal with the added complexity a hydronic coolant heater will add to this system, please accept that, for me, this type of conversion is consistent with the objectives I have in mind for an overland hunting camper. It may not be consistent with your mission parameters, but you are not the one paying for this conversion, nor are you the one who will be using this camper in a third-world combat situation.
Gibberogill
Idaho
With that out of the way, I would like to know how those of you more experienced with the 6.5L platform (non-turbo) than I am would plumb the hydronic heater into the coolant system.
Here are my thoughts:
1. The line of heated coolant going from the hydronic heater to the engine I thought should be plumbed into the lower radiator hose to allow for the engine block and heater core to receive heated coolant prior to engine startup. Coolant in that hose is under the lowest pressure of anywhere I could plumb into in the coolant system. This makes the pressure differential of that location the most advantageous to pump heated coolant into from the Espar unit. On the other hand, I have read that coolant should be removed from the lowest part of the system to reduce the incidence of introducing bubbles into the hydronic coolant circuit. Any thoughts?
2. Where should I wye off to transfer pressurized coolant from the engine to the Espar unit? Ideally, I think it would be best to take the coolant from the back of the engine where the coolant is still under pressure. Taking coolant from this location would allow heated coolant from the Espar unit to transfer that heat to the engine block and heater core before going back to be reheated. It would also assist in pressurizing the line going to the Espar unit. Without removing a freeze plug and adapting a barbed fitting to the engine block, what would be the best way to accomplish this?
I appreciate any input that can help me solve this problem. Thank you.
JB007
Idaho
Following. I'm looking at the same installation on an M1083. If anyone has done this add thoughts and photos, please.
coachgeo
3,546
North of Cincy OH
several birds one stone.
Get an APU (Aux Power Unit) for a Big rig.
it's a Charger/ jumper for your truck battery .
--throw a switch and charge camper batteries...
--quieter than many diesel generators
AC
some have built in small AC (and heat) so you get AC or heat even if camper batts to low.
HEAT
most all water cooled units also include engine/cab coolant heater
--start up heat for drive engine, while topping up batteries.... (if it is a water cooled APU).
--Can use same to preheat camper with flip of a valve.
Add a diesel fired coolant heater into the line and you can heat engine coolant/cab or camper or APU's coolant or any combo (which is my plan... both APU and diesel fired coolant heater).
PS-am using vintage 1940's heater box for camper coolant heating. may need to upgrade the components?? like one below
chucky
19,296
TN .
They used to make what was called ARTIC FOX fuel heater you could order rite from the factory on commercial trucks ! I had 1 on a 425 cat in a kw in 86 that worked great in super cold conditions but figured out on a dyno at a cat dealer in billings mt that on my 425 i was losing 45 hp when the fuel heater was keeping the fuel hot so they installed a cut off valve in line we let the fuel cool back down to current outdoor temp and gained 45 hp on the dyno so you might weigh that into your decision ! And ive operated in 60 below in canada winter only using HOWES fuel conditioner plus all diesel fuel in canada in the winter is blended for the cold so i cant see a reason to use a fuel heater at least here in the states and as far as heating the water they make block heaters that install in a freeze plug hole on your main engine kind of like the heating eliment on a water heater in your house but you would have to figure a way to pump the water while the main engine is off and your heating system in the habitat be able to take 15 psi when the big engine was running
ckouba
1,992
Oregon
My experience starts with a PSA of "Don't do it this way", and then a way that works:
I selected a line which I thought was actively pushing fluid, but I was wrong. Actually traced back the plumbing, selected the correct hose, and all good now. I highly recommend it, but there are others who have a different opinion about it. Do what moves you.
Chris
