LongsPeakMoto
- 29
- 13
- Colorado
Hello everyone hope this is the right form!! This is my second post so please bear with me.
I recently purchased a 99 m1088a1 that I am turning into a camper. I have a few problems I'm trying to figure out and hope to get some help. The first problem I am having is my blinkers are intermittent. Sometime I start up and turn my lights on and drive, only to have no turn signals and no hazards. Other times I do the exact same thing and magically they work, completely normal. I have tried resetting the "fuse" with no luck and even turned the car off and back on with no luck. It really is a hit or miss on if they will work or not.
My second problem is almost all the lower dash lights are lit up and won't turn off. This includes the ctis overspeed, dump lift, abs, and the blinker lights to name a few. The previous owner said it was one of the transistors on the lower right side of the circuit board. (I have not replaced it yet because I was wondering if this even made sense as a possible solution to the problem) *I put a photo of the dash below. The parking brake light does shut off its the bottom row that stays on.
My third problem; that scared the crap out of me the other day, was my ABS not turning on. It was raining a few days ago and as I was coming up to a yellow light, all my tires locked up and the truck started turning sideways. luckily I used to drive a 26ft RV up the rocky mountains weekly in the middle of winter and was able to counter steer and control the truck. This issue tho has me a little more concerned for winter driving tho. (Not sure if this has anything to do with my second issue though)
Thank you for the help! If I am on the wrong form please let me know so I can switch it over.
