rcamacho
- 915
- 93
- Bainbridge Island Wa
I’m following TM sequence to service LH valve cover gasket. Plenum crossover and LH manifold must come off in sequence so as to not bend injection lines.
TM 9-2320-387-24-2
Sections
15-20
15-16
16-4
15-11
The problem is there is not enough clearance to remove crossover from turbo outlet. A pillar close out panel and dog house retainer have been removed per TM. Need 1” more clearance. Note crossover is not the cut and welded version.
looks like I have to lift the whole body or pull the turbo off.
TM 9-2320-387-24-2
Sections
15-20
15-16
16-4
15-11
