- 14,206
- 1,571
- Dayton, OH
Now I thought it would be easy to find an answer using the Internet but I was mistaken.
It's simple, where is the best place to add a quick disconnect hose fitting (with valve) to the air system that I can use to pressurize the truck before start?
I do not want to screw it up or introduce an issue into the braking system.
I can use gladhands AFTER it is running for air.
Reason: I try to keep the truck inside and it bleeds down eventually and if I start the truck inside to air it up eventually the CO will be too much. Even as big as my barn is and with two 20 foot doors open it is a little much in there.
thanks in advance
thanks in advance
