M1114 Power steering issue??
hedcrash
10
Washington
I have a newly purchaed M1114 with hydraulic winch, I say that as I am learning about the hydraulics still. My issue is I have a hose that when purchased was disconnected so trying to get it fixed up and not damage anything:) The hose appears to come out of the hydraulic selector (if I am correct) its the hose on top in the picture and goes nowhere. I already have hose to my fan shroud so thats not it and at the base of the fan where a T juction is on an M1151 this model doesnt have one. So I am wondering where it goes?? I thought it was power steering but have not found the correct place for connection. Please help:)
Mogman
10,452
Papalote, TX
WELCOME to the SS forums!!
Here is the troubleshooting guide for the winch, it has hydraulic schematics for the steering system (fig 3 or 7 if you have the remote reservoir), I hope this will help.
It could be several things including someone bypassing the cooler in the rear diff which I understand is somewhat common, but I have no experience with this model.
hedcrash
10
Washington
Appreciate the ideas above and will check tonight. Whoever moved it to correct thread sorry about that but appreciated.
hedcrash
10
Washington
If anyone knows is the first picture above the pressure relief valve or the valve body assembly. ??Thanks all
Mogman
10,452
Papalote, TX
[/QUOTE
It looks like the relief valve the valve body has wires to the solenoids that activate the valves.
Mogman
10,452
Papalote, TX
Figure 4 is what the valve body should look like, it has 4 hoses. (not shown in fig 4)
Mogman
10,452
Papalote, TX
If you have a diagram or TM link please let me know so I can learn where to plug in. Appreciate all the help here.
All the information you should need is in the attachment I posted above. What 86humv is referring to is the pressure relief valve in the figures 3 and 7 depending if you have a remote PS pump reservoir (fig 7) or not (fig3), this regulates the flow to the rear diff.
This is the best hose and flow schematic I have found for a truck with a winch. (but others may have something better.)
Where does the disconnected hose go? simply follow it.
hedcrash
10
Washington
With all the above posts and comments I did find the hose and where it is 'supposed' to connect just odd my truck does not have the T junction to connect to. This is the closest diagram that explains it all.Screenshot 2023-12-20 at 17-46-21 9-2320-387-20-xx.PDF - mwo-9-2320-387-20-1.png
