M1151A1 HMMWV plenum crossover removal
rcamacho
915
Bainbridge Island Wa
Body mounts were just slightly compressed 😂
LT valve cover, intake manifold and plenum are back in. Front two mounts are in. Need to address the next (4).
Found the balancer has failed - outer ring came off and is contacting the oil pan. Looks like the cooling stack has to come out yet again to replace the balancer 🤦‍♂️
Retiredwarhorses
4,602
Brentwood, Calif
Those are REV body mounts, and the stack does not need to be removed to replace the balancer.
rcamacho
915
Figured I’d upgrade to the REV style mounts. Thanks for the tip on balancer replacement that’s a relief
Finished installation of all the body mounts. I was able to reuse all the hardware without having to use longer bolts.
90ft/lbs seems a tad excessive on the mounts IMO. Gather the factory spec wants metal contact between the center sleeve and the lower bushing plate.
