LMTV: winch on the deck
tennmogger
544
Greenback, TN
Considering a quick-detach winch to drop into one of the four 4" holes on the LMTV bed where the crane went. What do you all figure it could handle? Pulls would be in shear force across the deck. I am assuming a 9k lb winch would be no issue. A double line could return to the chassis to halve the pull on the bed.
Ronmar
7,505
Port angeles wa
Not sure how much lateral force the bed mounting scheme was intended to withstand, havn’t really looked at that structure…
serpico760
1,763
San Diego, CA
Considering the mounting tube is welded to the top and the side rails and the bottom layer I'd say could probably withstand a considerable Force!
serpico760
1,763
San Diego, CA
Does anyone know what type of steel this bed is made from because I think I'll make a cad model of the bed on my M1083, and a 2-ft shorter version for the M1078. applying the proper material could lead to good results from FEA
aw113sgte
975
La Crosse, WI
I can almost guarantee that CAD model is very inaccurate. Even if dimensionally perfect, the details needed for an accurate FEA are very technically complicated. Unless you are an engineer doing FEA on a regular basis and understand all the factors, FEA on an assembly structure like this is going to present you misleading information.
I see many errors on FEA assumptions made daily by PhDs. It's a powerful tool but you really have to know what you're doing.
Wingnut13
563
Strafford, NH
My .02……
Just from looking at it I’d say you’d have no problem with a 9k winch. If you double line winch I’d maybe go back to the truck frame. It’s probably one of the best places on the truck to pull from excluding the frame itself.
