Speed sensor transfer case.
Xengineguy
831
USA Indiana
I’m looking for a used or new speed sensor for the output of the transfer case. (Easy to access under the access plate on the rear of the transfer case) Does anyone have the part number. I looked in the TM and didn’t see it
listed? Thanks.
DeMilitarized
1,079
Gainesville, GA
listed? Thanks.
Should be this. I had a 2511 code in my M1083a0 and needed a transmission rebuild from a blown pump.
29505601
Xengineguy
831
USA Indiana
29505601
Thank you! I’ve checked the sensor and the resistance is way off compared to what it’s supposed to be and compared to
my other truck. These things keep you busy!
DeMilitarized
1,079
Gainesville, GA
I sold my 3 FMTVs because they were taking too much of my time. My M932a2 in comparison is a fraction of the headaches. Both have pros and cons just didn't like the pros enough to justify the time.
Ronmar
8,212
Port angeles wa
Yea there are several places for issues: sensor to bulkhead, bh to harness, harness to cab bulkhead connector and cab BH to internal connectors on TCU. In the case of my interference issue, it could also be a shield or missing ground along the path, or leakage in a contaminated connector...
Xengineguy
831
USA Indiana
Yes I’ve went thru everything from the sensor all the way to the front bulk head connector. All good no cross feeding and carried enough amperage to light a Lmtv headlight. With the resistance difference I’m leaning toward a sensor. Thanks
DeMilitarized
1,079
Gainesville, GA
better pull out your wallet bc the only ones I can find are $1k 😭😭
coachgeo
3,531
North of Cincy OH
I think they won't sell to normal people anymore. Also says " Wholesale Inquiries Only! " on website. They just sent me to my local allison dealer.
yeah I knew Ted sadly went to wholesale. Am saddened more; hearing that they won't tell consumers who is a vendor that sells their surplus parts. I'll ask him how to find out.
