Tire pressure
walkerbzz11
41
Tennessee
The former owner of my M1008 lifted the truck 4 inches and put 37x 12.50 16.5 tires on it. I believe what comes on a hmmwv. What air pressure should be in these tires when placed on a cucv? Also, what if any, added strain is put on my truck because of these modifications? Thanks.
Barrman
2,188
Giddings, Texas
You get to be the test pilot on that one. Loaded to the gills I would suggest putting the tires at the pressure the side of the tire says is max. Running empty that will have you bouncing off the ceiling and your teeth getting rattled out.
The rear tires are going to be whatever psi you are comfortable with running empty. Probably between 30-40 on pavement.
You can treat the fronts the same. I like to find the line between the steering wheel feeling 1 finger light at 50 mph and feeling full hand heavy. Probably in the 34-39 range depending on your alignment and condition of the parts.
Off road depends again on what you are doing and how fast you are trying to go. The lower the psi the smoother the ride and the better the grip. Until somewhere in the mid to low teens. Then your tire will come off the bead and you will be stuck.
MarkM
1,149
2,099
WOBURN. MA.
If you put them at full pressure on a lighter truck than the HMMWV you will have a rough ride and wear out the tire tread center a bit faster
For that truck I would try 40psi and see how she does. I run 50psi on my M998 as it smooths out the vibrations on the highway (need to have the tires rebalanced) and steers a bit easier and I have not noticed any unusual wear. My tires are MTRs.
Just my .02 cents.
Mark
MarkM
1,149
2,099
WOBURN. MA.
One thing I ran into is I had a really slow leak in one of my tires and would not notice it looking at it until it was down to about 10psi. Not good so I purchased the little tire valve caps that show green at 50lbs and above and red at about 45lbs. Tgey come in all kinds of pressures. Great peice of mind.
Mark
Tire valve pressure caps
walkerbzz11
41
Tennessee
Ok. I can't find the recommended pressure on the side wall. I'll just trial and error it for a bit. What do you all think about it being lifted? I mean it looks cool as can be but Ive never been one to modify something that was built by someone a lot smarter than me. Thanks
MarkM
1,149
2,099
WOBURN. MA.
What tires do you have and what shape are they in? As I said I personally would try 40psi for your truck.
Mark
MarkM
1,149
2,099
WOBURN. MA.
The pressure info and what load range the tires are are needed to help you choose the correct road pressure.
87cr250r
2,131
Rodeo, Ca
I've got 37x12.5r17 tires on mine. 35 psi works well for regular driving. Lower pressure helps prevent death wobble if you've got other issues in the suspension.
