Is there a way to run Optima batteries in the HMMWV?
majorhavoc67
Lincoln NE
Only asking because my brother gifted me 2 brand new yellow tops for Christmas. Curious if these can be used somehow, or if a specific battery is needed?
Coug
4,762
Olympia/WA
As long as they physically fit in whatever location you want to mount them, and you can secure them.
Also, the original 6TM battery was rated around 660CCA, so as long as they are above that you should be okay.
I've been told the HMMWV will even start on a pair of lawnmower batteries, but that was in commifornia, so probably didn't have to deal with colder weather like you might get in your neck of the woods.
majorhavoc67
Lincoln NE
Very good information. If lady luck looks in our direction, we might be joining our USMC son at Camp Pendleton. No more freezing weather, and I already have a way to legally drive a HMMWV in CA.
Milcommoguy
2,402
Rosamond, CA
They have spacers made for this swap to go from the 6TL to the Optimas. I run the red tops (like the ones below) in my 91 M998.
Mark
Not to be that guy... BUT the hold down bracket is close to becoming a fireworks display in the picture above.
A big bump and sparks could fly. That Guy, CAMO
MarkM
1,148
2,098
WOBURN. MA.
Yeah that pic is not my HMMWV but you can set up the batteries up properly without issue. Below is my truck. You can see the tape as an attempt to cut down on the creaking sounds which in these trucks us an effort in futility.
Mark
juanprado
3,174
Metairie/La (N'awlins)
Mark
Are those red round boots military or ______?
If military, do you have a part number?
Godspeed131
984
Knoxville, TN
The rubber terminal boots are in the Parts TM the kit number is 5935425 the nsn is 5340-01-378-5201 for the boot and 5340-01-378-7525 for the cap. I used them on mine. Also the plastic battery hold down NSN is 6160-01-593-1062
