KDS Smart start issues
jjb
Newton/NJ
I have an M998 (rebuilt in 2005) with KDS smart start box. The wait light does not come on, fuel gauge isn't work but all other gauges seem to work fine. I can get it to start with starting fluid and it runs fine. I opened the box and see what appears to be a burned diode (see picture). I tested with an ohm meter and get 100ohms. No idea if that is good or bad though. I also tested a couple of the glow plugs and get no reading. Do I need a new EESS or is it just the bad glow plugs? I am worried if I just replace the glow plugs and there is some other issue it will just burn out the new ones.
Not sure if its related but with the key off when I connect/disconnect battery cables I get some light arcing. I do not see that with my M1097.
Mogman
10,161
Papalote, TX
You need new glowplugs and a new EESS box and never use ether on that engine again that is strictly taboo.
jjb
Newton/NJ
What other option is there to start it when the glow plugs are not working and its 20 degrees out? I generally only use ether to seat stubborn tire beads :)
Valor
228
Apple Valley, Ca.
Try WD-40 instead. No ether, starting fluid. That "diode" that looks burnt is a resistor. From looking at the colored bands on it, it just might be a 100 ohm resistor. It got hot for some reason. Good luck.
MarkM
2,058
WOBURN. MA.
BBROYGBVGW. Those of you with some old electronics background will know the meaning. I learned it some 40 plus years ago.
Mark
thompsoncustom
112
iowa
I haven't had any start box issues yet so no experience here but I would try and diagnose it before buying a new one. You already got the box apart so might as well replace that resistor if you can see the color bands on it or find a picture of another KDS board. Hows the rest of the board look? Any idea on what voltage and for how long you are getting power to the glow plugs?
  • Like
Reactions: jjb
jjb
Newton/NJ
I didn't get that far yet.
Sent from my Pixel 8 Pro using Tapatalk
Mogman
10,161
Papalote, TX
Actually it is BBROYGBVGWGSN
I'm not sure the little jingle would be appropriate to list here, it starts with "bad boys"
The N stands for no band or "now" in the jingle
TOBASH
3,833
Brooklyn, NY
Fix the box more or less permanently by following the link
