M1078A1 Fuel line lengths
Wingnut13
565
Strafford, NH
Hey all…. Does anyone have the answer? I’d like to get my suction line replaced and need the length if anyone has it handy. I did search and came up with nothing useful.
2003 M1078A1 3126B engine
Thanks -Wingnut
GeneralDisorder
6,078
Portland, OR
I would highly recommend replacing them all.
I can't tell from the TM which line is which, but the two lines to the tank - one is 72" and one is 123" according to the NIIN characteristics.
Are you wanting the forward most line or the rearward most line? The forward line is 123" and the rearward line is 72"
Wingnut13
565
Strafford, NH
I replaced both suction and return lines this morning. NAPA had the Gates field assembled -6 JIC fittings and the hose. Total cost was about $120. The fittings take about 3 minutes per to assemble with an impact driver 13/16” deep well socket.
I also replaced my primary fuel/water assembly as one of the check valves has failed internally and it is not user serviceable in any manner. I just figured now was the time for the fuel lines too.
I did not replace the other interconnect fuel line on the engine. NAPA only had the four fittings I bought. But I will get to them eventually. They look to be in much better condition anyways.
Ronmar
8,254
Port angeles wa
#6 JIC females on both ends. I used 5ft of hose for the return line and 6ft for the suction. I used Parker pushlok line and fittings so it's just cut what you need. No reason to have hydraulic lines made.
Which specific model push-lock did you use? The issue with the cat fuel supply lines is that they are ALWAYS under vacuum. Not all push-lock fittings have high vac ratings, their spec info shows several as low as 10KPa, which is less than 3” of Mercury… crimp fittings are typically a LOT higher…
simp5782
Feo, Fuerte y Formal
9,506
Mason, TN
We use 836 hose.
Doesn't matter the engine. Cat, cummins, JD, Case, big or small it doesn't have any issue with any fuel delivery.
We see some failures when using them on coolant systems when In close proximity to exhaust the interior of the hose seems to get eaten up a lot easier at the 280 to 300 degree temps which it is still rated for.
Carowockner
Boulder, Colorado
Hey y’all. I’m replacing fuel lines on a 1078. I have a hydraulic hose that’s the right length and has the right fittings. I’m trying to figure out if it’s a good move to use it or if I should buy all new lines that are just for diesel fuel and not hydraulic. I know manufacturer’s recs are going to be use fuel lines but can I do it without the line degrading in a year or two, or not?
Ronmar
8,254
Port angeles wa
It should be fine. .. It will be a little thicker than a basic fuel line, but routing space is not really an issue on these trucks except alongside the radiator…
