thompsoncustom
- 112
- 43
- iowa
Just a little story for ya on my first time changing one of these tires.
after getting the tire off I unbolted the plate and tired it on the tire machine which didn't work so I thought to myself I would put 4 nuts back on the rim to keep it from flexing so the machine could break the bead and of course that didn't work either.
Decided I would run over half of the tire with the telehandler which has enough weight to really push down on the tire but no dice so I decided to put a diesel truck on the other half of the tire that's sure to work right? Nope still nothing at that point I decided maybe I should take the 4 nuts off and see if that helps. Yup came off easy after that. The next tire I was able to do on the machine and with bars/hammer doing it the right way taking the front plate off.
But it got me thinking even if your humvee had 0 psi in the tire when driving it's never coming off the bead.
Has anyone ever rolled a tire off the bead when driving with no air?? Only talking about the OEM setup with the run flat installed.
