Ronmar
- 8,138
- Port angeles wa
Waaay up route 20...Marblemount, WA
Probably won't work since the failure is the rod you are looking for with that tool has come loose on one end or the other typically. You might be able to catch the arm of the latch but it's pretty short.Man im glad im not traped inside waiting on yall to get me out ! Just get a slim jim ( flat stainless thin metal roughly 1in wide by 2 ft long with a hook cut out of the end and slip in between the glass and th metal door window felt wipe and go fishing for the linkage rod to hook and unlockhttps://www.googleadservices.com/pa...L6SpeyEAxU_5ckDHeO9CYEQ9aACKAB6BAgCECo&adurl=View attachment 918822
[/QUOT] hmmm...... thread starter has not defined enough about what is problem with door handles. DId the handle(s) brake off on the outside? Or are the handles fine on out side and rod is off? Or is that little arm the handle moves broke.... orrrrrrrr heck..... we dont even know what handle it is yet..... sooooooo maybe a slim jim would work??
