maggie8264
- 10
- 3
- Tennessee
My front left hub was leaking at the input seal. But when I went to change, the bolt holding the half shaft in the hub was tight and rounded off. I wasn’t able to remove, so I took it to a local shop. They got it out and replaced the seal and discovered the two boots on the half shaft were torn. I bought a new half shaft which they installed. However they called me today and said the bolt holding the half shaft in the hub would back out when in reverse. Said everything was installed according to specs. I am baffled as to why.
