DampLemonade
- 43
- 18
- Cannon AFB, New Mexico
Hi all,
I got a little bit of spending money and I think I want to attack replacing the injection pump on my 923 A1. It currently works, it just leaks some diesel from old gaskets (only when running) and the internal part where the tachometer cable threads into is broken so I don't have a working tach. Replacing the pump should fix these annoying little issues.
The TM makes it seem not too scary, but I was wondering if yall had any tips or "gotchas" before I spend a couple thousand on a new pump and then accidentally destroy my engine (or worse, have to get it towed to the local semi truck shop). I've only ever replaced 12v gasoline fuel pumps up until this point.... haha
