Cannon plug comparison
FarmingSmallKubota
1,392
Wapakoneta, Ohio
I am looking to buy some cannon plugs to make a few cord sets for these 1000 watt generators i bought The part number on the male end of the cord that i need is CA3106E16-10PBF97. Looking online it appears they are like $78 any insight into a cheaper option would be appreciated. I have found some on Ebay but not exactly correct and i do not wish to busy something i can't use. The image below is what was offered on ebay if someone could say if this is going to work that would be great.
Light in the Dark
6,775
MA
Why not just swap whats on the machine with something more readily available and modern, and source the mate that way?
FarmingSmallKubota
1,392
Wapakoneta, Ohio
Unfortunately not a lot of options. This is on a Innipower/yammaha ie1000 watt generator. If there are plastic equivalents i will do it, but not sure how to look these things up. I can't put a standard 110 outlet in
Poccur
146
Roanoke, VA
You could change the black power panel back to the original and then drop in a receptacle....looks like partzilla have the panel for about $27...
FarmingSmallKubota
1,392
Wapakoneta, Ohio
I see the panel, but i would also need the 12v outlet so we are just under what the plug cost, but I am going to open one up and look at the wiring to see how much needs changed. I have one of the first versions of the generator with regular face on it as well so i can compare.
