ECO Hubs Who needs 3:07 gears?
GeneralDisorder
6,139
Portland, OR
Lots of issues with just about everything that guy has to say. Clearly doesn't know his fourth point of contact from a hole in the ground. Please don't go on YouTube and talk about military :poop: like you know about military :poop: when you clearly haven't been in the military and aren't qualified or knowledgeable. Definitely DO NOT tell people the hand throttle is a cruise control. 🤦‍♂️
NOT Subscribed.
MatthewWBailey
1,903
Colorado
NOT Subscribed.
I hear He's interested in going to the S&S school of hard knocks. 😂
GeneralDisorder
6,139
Portland, OR
In stock form the hand throttle won't work as a cruise control because it's not supposed to bring the engine up to near redline so it won't let you do highway speeds. But with the ECO hubs it probably kinda works. But won't disengage when you hit the brakes, etc. Using the hand throttle for such foolishness is probably going to get you a personal meeting with the First Sargent or worse. That's a PVT Snuffy peeling potatoes on KP for a week type of "mistake". Don't do that - don't even joke about it. That's how accidents happen in convoy and soldiers get hurt or dead.
AKPacker
225
Anchorage, AK
These have been out a good while now and I have yet to see any negative reviews or major issues crop up. They're on my short list of "must have" upgrades to install before I drive my truck home and were a major factor that swayed me back into wanting a LMTV.
What sort of long-term fuel mileages are you guys with C7 trucks seeing?
GeneralDisorder
6,139
Portland, OR
In the neighborhood of 10. Depends on how fast you drive.
AKPacker
225
Anchorage, AK
A couple heavy boxes arrived in the mail today! Has anyone run Ecohubs with 14.00R20 tires and stock 3.90 gearing? Would that be too tall for the engine to cruise in the happy zone of the powerband at ~60 mph?
Ronmar
8,326
Port angeles wa
Well I imagine it would be similar to running them with standard size tires and 3.07 gears and I am aware of a few that are doing that. None have any issues I am aware of. The C7 and 3126 have a little lower peak torque RPM, so I do not think it will be a bad match, and a little under pk torque is not a real issue and may even yeild a little better mileage, as long as you have enough torque to perform the work At that RPM. If you don‘t the trans will downshift… considering these things motor down the highway with 2:1 hubs, at max engine RPM with only ~1/2 of peak torque available, you should be able to do the same thing on the low rpm side(~1/2 of pk torque) of the power curve…
MatthewWBailey
1,903
Colorado
Let us know how it works out. Lots of trucks with 3:07 running eco hubs. I would bet you might not be in O.D. At 60 mph.
But that’s ok.
Hey I still have that setup. Only observation is that I never see gear 7 and only feel 6 kick in on flats at 75mph. The take-off effort is a little strained on uphill starts (my drive entrance to the main road is 10% grade for 50'). So when I go back to 3.90s soon, I expect I'll simply be running in 6 more with occasional 7. But I'll have better start out in 2.
Ronmar
8,326
Port angeles wa
Do you have a tach, and do you know your vehicle weight? RPM during that 2nd gear start up a 10% grade and your weight would give us an idea exactly how "strained" that type of a start is...:)
MatthewWBailey
1,903
Colorado
Tach goes in on Tuesday lol. Weight was 17400 at the last scale i was on. Rpm sounded like the same level as the high idle but it's just a swag.
