Rate this front bumper modification...
TechnoWeenie
1,797
Nova Laboratories, WA
Wonder why they didn't line up exactly?
The opening is offset. It's not centered. I learned that the hard way when installing lights into the bumper.
So, when it's flipped upside down, the offsets are on the opposite side.
If you've never paid attention to the front bumper, you might have missed it.
Superthermal
1,037
Utah, Murray, United States
Good to know! I am considering flipping mine and mounting my winch about 8" higher up on the frame to keep the lateral guide rollers up out of harms way. I will pay a bit more attention now that I know this is the case. Thanks for the knowledge that only comes from those... "Oh... that's not what I was expecting" moments.
Jbulach
2,400
Sunman Indiana
Not good if you do much off road, the approach angle on the winch trucks is already terrible. Although if you’re dragging the front bumper a lot, you need to start watching your fuel tanks so you don’t rip it off.
TechnoWeenie
1,797
I have a winch-less truck. Was tempted to do the above mod but I also thought it might be a bit too low.
  • Like
Reactions: 98G
M813rc
3,873
Near Austin, Texas
A couple of folks on here have done that over the years.
I remember one bobbed deuce with a utility bed that looked particularly cool, though I don't recall the notches being off-center.
Edit - Found some pictures. I don't recall whose truck it is/was. He doubled up the frame in the back for the trailer hitch too.
Cheers
swbradley1
Modertator
1,939
Dayton, OH
I suspect after seeing them driving the streets of Baghdad the bumper was added to clean the street of vehicles. Because of the truck's high original bumper you run the risk of driving up onto something and getting slowed down or hung up. A poor soldiers snowplow for shoving cars out of the way.
Jbulach
2,400
Sunman Indiana
Yep, especially on a gun truck where you likely have to quickly push one of your own. Would also want some good reinforcement to keep it from just folding under.
Defcon-1
67
South New Jersey
Totally off topic: are these directional-tread tires? Looks like this tire should be installed on the R/H side of the truck because the "arrow shape" of tire tread pattern is rotating up instead of down? Asking because I have spares of these tires and was wondering if they could be installed on either side of the truck lol.
Jbulach
2,400
Sunman Indiana
Yes, Michelin XL is directional tread but I don’t believe they have directional arrows on the sidewall. I believe the trucks were built with them in the correct orientation, after that all bets were off, and spare and such got installed on whatever side of the truck was needed. I had several “backwards” when I got my truck and had no issues.
  • Like
Reactions: 98G
Defcon-1
67
South New Jersey
Ok that sounds good, I need to install one of my XL tires in the spare-tire location and I wasn't sure if it would matter what side I needed it for. I guess I'm not going through water at 50+ mph where I would need it to sling in the correct direction lol. I'm glad to hear you ran these "backwards", now I feel way better about replacing some of my dry-rotting ZXL for the XL spares I have on hand, ty 🙏
Jbulach
2,400
Sunman Indiana
Sorry for taking us farther off topic, but you should do a search here on SS about XL’s. Don’t “upgrade” to older tires, no matter what your ZXL’s look like.
Defcon-1
67
South New Jersey
No worries, ty I will. I lost (x2) ZXL's in the fronts (due to cracking in the sidewall) and then I had Goodyear AT-2's installed in place (as they were spares). But I'm out of ZXL's and AT-2's and have some XL's as "backup tires" just in case I lose another ZXL. Trying to save up for 16.00 R-20 to replace all 6 (plus spare) at once lol.
G744
4,119
Hidden Valley, Az
I've found radials take a 'set', directional-wise when new, and usually don't last too long when in reversed rotation.
Used tires are always a crapshoot, and I run them in all positions and hope to get my monies' worth. I usually do, as most of my tire failures are from foreign objects, and any flat with a super single whilst on the road means it will self-destruct in a hurry.
