Anyone have picture of properly mounted air brake load sensor valve on an m1088?
Reworked LMTV
1,545
1,205
TN
I need to re-attach the load sensor air brake valve on my M1088. Anyone have a picture of this mounted that I can use as a reference? Thank you in advance!
Reworked LMTV
1,545
1,205
TN
Just need a quick picture of how this brake load sensor is mounted. I took the 5th wheel off and am trying to recall where it was mounted. Thank you in advance!
Reworked LMTV
1,545
1,205
TN
Still need a picture of this item mounted, if you can spare the time : )
Godspeed131
970
Knoxville, TN
@Reworked LMTV , here’s the pictures. The first three are from the back facing forward and the last is from the front looking back.
coachgeo
3,531
North of Cincy OH
did a search for 1088 images etc. came across this video at 1:39 there in the rectangle spot that is sunlit, between the chassis rails, right side, you see what I think is the cable going up. Hope this helps.
coachgeo
3,531
North of Cincy OH
@Ronmar just posted a picture from birds eye that might help conceptually. Its I think a 1079 though. Granted I think you got this figuredd out now and moved on.
Not sure from any of these pics where the cable from the arm attaches above to the bottom of x (x=bed, box, etc) though not sure that matters.. just as long as that cable is vertical?.
GeneralDisorder
6,072
Portland, OR
S&S or the military or both deleted that on later trucks - I assume the ABS make it irrelevant or possibly it interferes with it's operation. If it's not the ABS then perhaps there is some other magic that could be adapted to older trucks? I'm far from an air brake system specialist but may be worth discussing if for no other reason than to understand how and why it was deleted.
