In tank fuel pump substitute for M35
2deuce
188
portland, oregon
I've seen the price of original pumps, and wondered if there was some work around that didn't empty the wallet. They certainly went up in price since I bought my last one.
What pressure and volume did the original put out?
Thanks
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Thanks
I use a 24v Carter vane pump mounted on the firewall in the engine bay. gut the old pump and put a pickup hose on it In the tank.
P4603hD
biscuitwhistler37
1,221
Michigan
I've read people have used 24v Walbro in tank marine pumps with success, a bit pricier than some but still half price of an original pump. I really like simps idea though, hard to foul a pump out if it's not in the constant fouling grossness that is the deuce fuel cell.
2deuce
188
portland, oregon
I looked in the tank, and it looks surprisingly clean, it is a 1987 truck, so it's not as old as some. If I remember right I think the pump runs slowly, and makes a lot of noise doing so, but doesn't pump anything. How are they resurrected?
KN6KXR
647
Felton, CA
Pull the pump and check it out. Mine was filthy but even after cleaning would only run upside down. Since it's really hard to drive the truck that way I needed a new one.
Honestly the stock pump is a crappy design. Why replace it with the same junk? I installed a Walbro for half the price and haven't looked back. Actually I scored it on eBay for like $50 so there's a place to look for a deal. Heck the hoses and fittings cost more (I upgraded to a premium modern hose instead of the hard lines). A good marine diesel pump like the Walbro will last a really long time. The stock one not so much.
fsearls92
157
Charleston, SC
Honestly the stock pump is a shit design. Why replace it with the same junk? I installed a Walbro for half the price and haven't looked back. Actually I scored it on eBay for like $50 so there's a place to look for a deal. Heck the hoses and fittings cost more (I upgraded to a premium modern hose instead of the hard lines). A good marine diesel pump like the Walbro will last a really long time. The stock one not so much.
This is funny, as the original pumps have been in trucks for 50 plus years. Walbro on their site says their pumps will only last 10-20 years.
msgjd
4,117
upstate ny
somewhere in another thread on here is the actual psi and flow data on the OEM in-tank pump .. IIRC, it is miniscule psi, something like 2 or 3 but is not more than 5 or 6.. On a couple of mine I use a 24v carter inline pump with 10-12psi with no issue for several years, and wired with the in-tank wire..
The multifuels will start and run just fine with an inop pump as long as they don't lose prime.. If they run every day or two you likely will never know the pump is bad.. I can tell you an operational in-tank pump helps immensely with starting a truck that has sat awhile or has an air leak somewhere.. The difference can be cranking 30 seconds before it fires (or fails), versus it firing right up within a second or two
Jeepsinker
470
Dry Creek, Louisiana
Yeah, pressure requirement is 4-7 psi, but the volume at that pressure is most important. I'm not familiar with the pump you used, but with 3× the required pressure it likely provides enough volume for proper hydraulic head cooling as well. I see a lot of people use little clicker pumps with 1/4" NPT inlet and outlet, and they just don't understand that it doesn't provide enough volume even if it does supply enough pressure. Can't flow the same volume through a 1/4" and a 1/2" pump at the same pressure.
msgjd
4,117
upstate ny
... I see a lot of people use little clicker pumps with 1/4" NPT inlet and outlet, and they just don't understand that it doesn't provide enough volume even if it does supply enough pressure.
correct! the carter pumps i used are 3/8 flow-thru's so-that the fuel will draw even if fuel pump fails
silverstate55
Unemployable
1,095
UT
If you clean/rebuild your original in-tank pump, make sure to use submersible fuel hose and not regular hose… made that mistake once and it didn’t take long to swell up & cut off fuel flow as well as become a nasty mess to replace.
msgjd
4,117
upstate ny
If you're in a pinch and your fuel system is tight enough, you don't need an in-tank pump to drive the truck. Though it probably makes priming the fuel system a ton easier after a fuel filter change.
The M35A3 doesn't even use an in-tank pump - just the IP at the engine.
absolutely correct on all counts ! ..
If a system isn't 100% tight, the in-tank pump helps the multispew crank a shorter amount of time after it has sat more than a few months, or a month, or a week or a day.. Depends on the degree of un-tight :D
