M1008 overdrive switch?
Enforced_Leo44
Parma, Italy
Hi everyone,
Just got my hands on a '85 M1008, seems to run good and basically everything seems to be in good running order.
One thing that struck me and didn't really quite understand, is a supposed "overdrive switch" that the previous owner wired up into a floor switch near the pedals that looks like the highbeam floor switch that one can find on, say, a Humvee.
Supposedly the truck has a TH400 and the usual transfer case, which I think is a NP 205 since it has 2 sticks for its controls, so it should be bone stock, if not for a lift and bigger tires.
Is the PO just putting up some bs and making stuff up or is this "overdrive switch" something that actually makes sense? or maybe it has to do with the transfer case?
Any suggestion is gladly appreciated, thanks in advance.
This is a walkaround of the vehicle, the switch is not shown because it's in the lower left of the driver cowl.
20,760
Hi everyone,
It might be worth looking under the truck - where the wires would attach to the "overdrive switch" - and see where they go. Heck, it might be that he just installed the switch and called it that (never changing anything).
Enforced_Leo44
Parma, Italy
Yeah that was my first thought as well, one thing that it's wired up to is a little green LED light on the right side of the dash, but that's about it, didn't look deeply under the truck yet
Barrman
2,188
Giddings, Texas
Looking under the truck should be your next step. Engine, transmission with a bolted on transfer case. Then drive shafts to the rear and front. If there is another box bolted to the rear of the transfer case. Then you could have something like a GearVendors over drive unit on the rear drive shaft only.
Enforced_Leo44
Parma, Italy
That's a hint, the GV unit, I'll check under the truck for it next time I'll see it.
nyoffroad
742
Rochester NY
Could be a lock up torque converter, if so NEVER have it locked and come to a stop! 6.2 has enough torque to overcome the lockup clutch and will burn it up in seconds. I think I still have the Tee shirt somewhere.
BTW it's not stock if it has twin sticks for the transfer case.
Curtisje
698
Okinawa, Japan
My M1008 had a gear vendors unit on it when I purchased it. It was controlled manually with a switch on the floor, a switch identical to those old high/low beam switches on older vehicles before they started putting that switch in the steering column.
Good luck. Should be easy to figure out. The GV unit bolts onto the rear of the transfercase.
CARC686
706
New Mexico
That was my first thought. Those things are spendy, so it's a nice bonus if that's the case.
Enforced_Leo44
Parma, Italy
Yeah I contacted the previous previous owner and he confirmed that it's a add-on overdrive unit, didn't specify the maker but I don't think that anyone other than GV makes such things
